 回复 78# 蓝鱼o_0
 【surveillance】Part III
 Several surveillance methods exist, and infection prevention and control programs must decide which method is best suited to their facility. The most common surveillance methods include hospital-wide surveillance, prevalence surveys, targeted surveillance, and periodic surveillance (248). Hospital-wide surveillance is the most comprehensive and includes the prospective continuous survey of all areas to identify HAIs or epidemiologically significant organisms (248, 346). Hospitalwide surveillance is costly and may identify infections that cannot be prevented. This method is not commonly recommended. A prevalence survey determines the number of active cases (new and existing) of a particular infection or organism in a given area during a specified time period (259). Prevalence surveys can be applied to individual wards or an entire health care facility. Prevalence surveys can be used to determine the burden of a particular HAI or epidemiologically significant organism as well as assess risk factors for a particular infection within a given population. Targeted surveillance is focused on selected areas of the hospital, selected patient populations, or selected organisms (e.g., VRE, MRSA, or C. difficile). Examples of targeted surveillance include MRSA surveillance for ICU patients only or surveillance of infections associated with specific devices, such as VAP.  By performing targeted surveillance, infection prevention and control programs can focus on patients at increased risk and areas with high infection rates where interventions are proven to be beneficial. Periodic surveillance is used when surveillance methods are done only during specified time intervals. Examples would be hospitalwide surveillance 1 month every quarter or targeted surveillance rotating among different units. Periodic surveillance is less time-intensive and less expensive (248).  几种监测方法存在,感染预防和控制方案必须决定哪种方法最适合本机构。常用的监测方法包括综合性监测,患病率调查,目标性监测,定期监测(或者周期性监测)(248)。综合性监测是容易理解的,最全面的持续性、前瞻性调查,覆盖全院,以确定HAI和流行病学上有重要意义的微生物(248,346)。然而其很昂贵,确认的感染难以预防。通常这种方法不予以推荐。患病率调查决定在特定地区,特定时间内(259)存活病例数量(新发或者现患的,特定的感染或者特殊病原体引起的感染)。患病率调查可以应用到个人或整个病房的医疗设施。患病率调查可以被用来确定某一特定HAI的负担,或者重大流行病学意义微生物危险因素评估以及对目标人群的特殊感染的危险度评估。目标性监测在于集中于所选医院,患者人群或选定的微生物(如VRE,MRSA或艰难梭菌)。目标性监测的实例包括ICU患者MRSA监测或特殊设备感染监测,如VAP。通过进行目标性监测,感染预防和控制方案可以集中于危险增加的患者或者高感染风险区域,并进行行之有效的干预处理。定期监测(或者周期性监测)的监测方法通常用于特定时间段。比如在每个季度在不同的科室轮转,开展为期一个月的全院监测或者目标性监测。定期监测耗时较少且成本更低(248)。 New surveillance technologies are emerging. Computer software that integrates microbiological, clinical, radiographic, and pharmacy data has been developed. This new technology allows automated surveillance for HAIs and has been shown to be more efficient at identifying outbreaks than routine surveillance (357). Automated surveillance systems should free up time for IPs to focus on rounding on units, infection prevention, policy implementation, and educational activities. The future for infection prevention and control programs will require automated surveillance systems as information technology is expanding. In addition, IPs will need to communicate with those in the outpatient setting and IPs at outside institutions as the health care system grows more complex and patients need to be tracked within this complex system. With increasing emphasis on public reporting, the importance of standardized definitions and standard approaches for identifying infections cannot be overemphasized. Surveillance is the cornerstone of infection control and prevention programs; however, to be most effective, surveillance must be individualized to the needs of the facility and performed in a methodical and efficient manner. 新的监控技术不断涌现。计算机软件,集成了微生物学,临床,影像学和药学数据已经研制成功。这种新技术可以自动监测HAI的发生且已被证明在确定爆发时比常规监测更有效率(357)。自动监控系统可以随时辅助感控专家关注各个高危科室,感染预防,政策实施和教育活动。随着信息化加剧,感染预防和控制规划的未来需要自动监控系统。此外,感控专家需要与门诊进行进行沟通,并且外界机构的从事医疗保健系统的感控专家变得越来越复杂,病人需要这个复杂的系统进行跟踪。随着公开报道要求的强化,标准化的定义和确定感染的标准方法的重要性再怎么强调也不过分。监测是控制感染和预防方案的基石,但是,是最有效,监测根据设施的需求必须因材施教,并有条不紊,高效地进行。
